Ok, having only been here a few weeks i've already seen the 65mm TB this and Explorer intake that, low end tq blah blah blah crap that gets spewed around all the forums. So i am going to bring alot of my notes and experience all into one thread for everyone to look at.
So, you think a throttle body/intake manifold can be too big for a 302? So if i told you i was going to take a Edelbrock super victor EFI intake with a 90mm TB on it you'd probably all say i was crazy huh? And if i was going to put this on GT40 non-p heads with a custom ground camshaft, all the it'll make no low end torque, it'll have tip in-tip out throttle problems, WOT at 50% pedal, that is all bull$h!t and anyone who says different has no clue what they are talking about.
We will use 302 based motors for this discussion since that is what most are using, i will touch a little upon some 351 related info later in this thread.
An example of a few 302 8.2" deck height EFI intakes.
1. HO mustang/Mark VII intake
2. GT40 Explorer/cobra intake
3. BBK-SSI Intake-75mm inlet
4. Edelbrock Performer RPM II
5. Trickflow Track Heat-75mm inlet
6. Trickflow Street Burner 75mm inlet
7. Trickflow R series-75mm inlet
8. Trickflow Box R series-90mm inlet
9. Edelbrock super victor EFI With 90mm or 95mm elbow
-I will leave out the really high dollar intakes, Hogan custom sheetmetal intakes etc. for now.
-Options 1 and 2 are great budget upgrades over stock.
-Options 3-7 are great middle of the road stuff that you can buy used off corral, craigslist etc. for fairly cheap, and are great improvements over the GT40/HO stuff.
-Options 8 and 9 are for people who actually understand how to build motors, want to make the most power they can with their particular setup, and don't listen to the idiotic "too big" myths floating around.
Now, first things first. The main focus of this thread will be throttle body sizing, you can have the greatest intake in the world but if you bolt a tiny ass throttle body on the inlet it isn't going to mean shit.
I'll use one that always comes up on the corral, AFM, mustangforums etc. The "a 75mm throttle body is too big for a N/A 302" garbage. How can a throttle body be too big? It simply plays middle man between the intake and the outside air. I have no idea where the too big crap came from, maybe from the carburetor sizing days, where a restriction is needed just by design of a carburetor since it needs to pull air and fuel, whereas a TB is only letting in air, which is why carb sizing and TB sizing are non-compareable.
So the first myth that throttle bodies can be too big, lets look at some OEM examples. These are all cars i have worked on, measured myself, or had someone else measure for me to verify, im not just pulling these stats out of my ass from a google search.
-2003 Ford Escape 3.0L DOHC engine = 63mm Bore/58mm Blade
58mm/183 C.I.D.(cubic inch displacement) divide 58mm by 183 and you get .3169mm per Cubic inch, multiply that times 302 and you get= 95.7mm.
So you would need a 95mm TB to have a proportionately equal TB size to that little V6. Oh no, the list doesn't stop there.
-1997 Dodge Caravan 3.3L engine = 56mm bore/55mm blade
55mm/201 C.I.D. = .2736mm per cid = 82.63mm for a 302, 96mm for a 351
-2002 Kia Sedona 3.5L DOHC engine = 67mm bore/62mm blade
62mm/214 C.I.D. = .2897mm per cid = 87.50mm for a 302, 101.7mm for a 351
-2000 Nissan Pathfinder 3.0L engine = 65mm bore/59mm blade
59mm/183 C.I.D. = .3224mm per cid = 97.4mm for a 302, 113.2mm for a 351
-2005 Suzuki Aerio 2.3L DOHC engine = 65mm bore/60mm blade
60mm/140 C.I.D. = .4286mm per cid = 129.4mm for a 302, 150.4mm for a 351
-1995 Mercedes Benz C280 2.8L engine = 70mm bore/70mm blade
70mm/171 C.I.D. = .4093mm per cid = 123.6mm for a 302, 143.7mm for a 351
-2005 Lincoln LS 3.9L V8 engine = 82mm bore/70mm blade
70 mm/238 C.I.D. = .2941mm/cid = 88.8 mm for a 302, 103.2mm for a 351
-1996 Oldsmobile aurora 4.0L V8 engine = 75mm bore/75mm blade
75mm/244 C.I.D. = .3074mm/cid = 92.8mm for a 302, 107.9mm for a 351
So i guess all those OEM throttle bodies are too big too then? If you need more OEM examples i have loads of them right here with me.
Does everyone follow so far? Any questions please do ask and i will explain in full detail.
Next i will explain the tip in-tip out throttle BS myth where people claim a 90mm TB is at WOT at half pedal.
