Anyone else tried this? I just downloaded a copy last night just to play with it. The interface is similar to Desktop Dyno, with the upshot that based on details you provide, it spits out a list of suggested stock Comp grinds and displays projected peak and average power and torque numbers for each. Now I just need to take a few minutes and put in some actual head flow numbers, since as with DD, who knows what exactly the preprogrammed flow profiles are supposed to represent.
Free Comp Cams "CamQuest" software
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
My only problem with a program like that is that it's issued by a parts manufacturer, so whatever you put in, it's going to be rather optimistic in the final HP/torque numbers in order to encourage you to buy their cam.
At least, that's what the cynical side of my brain is saying.
Well, it also doesn't take into account things like gearing and converter slippage like Desktop Drag does.
I guess offhand I wouldn't worry too much about it trying to get you to buy one of their cams, because it only compares Comp grinds to other Comp grinds.2012 Mazda5 Touring | Finally working on the LTD again!
I wish you could enter custom cam specs, mostly so that I could see what I could get using an Explorer or even stock 351W cam.
It is good though, as long as you keep in mind that it's optimistic.
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
You can do custom cams in Desktop Dyno.
Originally posted by johnunit View PostI wish you could enter custom cam specs, mostly so that I could see what I could get using an Explorer or even stock 351W cam.
CamQuest is intended to help you match your combo with a stock Comp grind.
DD03 has the capability to even enter both the .050 and seat-to-seat duration numbers, and let it calculate a representative ramp rate based on those figures. If you want to get real fancy, you can download the Comp master lobe catalog and punch in any conceivable combination of lobes and centerlines that will fit on a SBF cam blank.2012 Mazda5 Touring | Finally working on the LTD again!
But racing computer dyno simulations is fun! Besides, they do at least provide a point of reference for those who aren't experienced racers (like most of us) and can, at the very least, point out obvious flaws in component selection and thus (potentially) save money.2012 Mazda5 Touring | Finally working on the LTD again!
True, but, are you putting together an engine from the ground up, or are you just trying to keep cost to a minimum? Cause this is where the difference is - it's entirely pointless to spend hours day in and day out with that software, if all you're after is 50 hp upgrade over a 200 hp factory engine...
Who said I was putting an engine together at all? This software junk is a way to toss parts at a motor at random and see what sort of screwy power curves you can get. I think we all know that the only really correct way to actually test parts is to toss them in a car and run it down a racetrack. The notion of reducing cost would be, for example, if one were on the fence about two components and could make a slightly more educated guess at what would actually work.
Though, I do agree that if someone were to actually spend "day in and day out" with the stuff, that person ought to consider counseling. And the best way to keep costs to a minimum is not to own a car.2012 Mazda5 Touring | Finally working on the LTD again!
just downloaded it, we'll see what happens, sounds intersting though!Parts Car (Scrapped ) - Vicky - 1987 LTD Crown Victoria: 17x8 Gunmetal Gray Coys C-5 wheels, 235/55-17 Falken Ziex ZE-502 tires. 79 LTD Grille, Taillights, and Turn Signals, Blue LED Dash Lights, PI Rear Sway Bar, 140 MPH Speedometer, Dual Exhaust w/ Mustang Headers.
Yeah, I wish I knew what cam was in my car. I'd like to get an idea of at what point it becomes the weakest link.
To be clear, I only have Camquest, and I guess what I'm saying is the main feature I miss on it compared to DD (which I've only used twice) is the ability to enter new cam specs.
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
John, if I find the CD I have laying around someplace I can send you Desktop Dyno and Desktop Drag in a .zip file. Then again, I may have left it at my mom and dad's house...
Anyway, if I run across it, I'll let you know.
That'd be great. I'd never leave this damn computer if I had DD.
