Have you checked the battery voltage to see if its normal? Could be something wrong with the alternator. Also, the stock belt setup has a hard time handling much over 150 amps, so you might be hearing a little belt slippage. Whoever modded the alternator for more output power may have also done something wrong. Stock output is 130, so something was done to it in order to get 200 amps from it.
