Want to do a tune up on my car, looking at mallory racing wires, new cap and rotor, new fuel filter.. anything I am missing? Let me know what you recommend.
What do you reccomend for a tune up?
- Oct 2009
- 2878
- Keene NH
- Send PM
1985 GMC 1500
Well plugs, air filter, pcv valve, oil change (if you havn't done it) and coolant change. Other then that everything else should keep her purring. Oh ya, and you might want to replace the thermostat as those tend to wear out and cause it to run hotter then it should or even overheat. Btw that is one hot MGM.1991 Mercury Grand Marquis LS "betsy" 5.0 lopo w/AOD with around 160k. Aka The Land Yacht aka Betsy.
- Oct 2009
- 2878
- Keene NH
- Send PM
thanks, can't believe I forgot plugs... I feel like an idiot. Running aimsoil synthetic and that has another 3k before I need to change it. May tackle flushing the coolant. The ford garage is going to be after me to do it when It goes in for inspection next week, they always offer for additional $$. Runs cool as is (according to dummy gauge) and has nice heat so thermostat is probably alright."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
9mm ford racing wires and motorcraft everything elsesigpic
Motorcraft caps suck, aluminum terminals. Anything with a brass terminal will do. I've used Accel and Blue Streak with good luck. I think right now I've got Napa Premium parts on both cars.86 Lincoln Town Car (Galactica).
- Oct 2009
- 2878
- Keene NH
- Send PM
thank you gadget."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
Originally posted by gadget73 View PostMotorcraft caps suck, aluminum terminals. Anything with a brass terminal will do. I've used Accel and Blue Streak with good luck. I think right now I've got Napa Premium parts on both cars.sigpic
I always use the brass caps, the aluminum ones corrode.....
Accel cap/rotor (ALUMINIUM TERMINALS)
Motorcraft plugs gapped at .052"
Ford racing wires if you can swing it, otherwise just any decent premium (not budget) set of wires
PCV valve, screen
Inspect vacuum hoses, especially the one to the MAP.Originally posted by gadget73There is nothing more permanent than a temporary fix.
+3 on the caps with brass terminals
change the fuel filter
It's always good idea to replace the t-stat if it hasn't been replaced in a while as they can get cooroded and gumed up thus causing a problem with cooling. Its cheap and if your going to do a coolant flush anyways, its worth the extra bit of work to make sure its replaced.1991 Mercury Grand Marquis LS "betsy" 5.0 lopo w/AOD with around 160k. Aka The Land Yacht aka Betsy.
Originally posted by jsawyer1181 View Postit's always good idea to replace the t-stat if it hasn't been replaced in a while as they can get cooroded and gumed up thus causing a problem with cooling. Its cheap and if your going to do a coolant flush anyways, its worth the extra bit of work to make sure its replaced.Originally posted by gadget73There is nothing more permanent than a temporary fix.
- Oct 2009
- 2878
- Keene NH
- Send PM
Alright i will take a look at that, but I do not think i am going to do a coolant flush just yet."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
Belts, hoses OK?
PeteOriginally posted by gadget73For other types of inquiry, more information is required. Please press 4 to speak to a representative who can help you with your question. This call may be monitored for quality assurance purposes.
- Oct 2009
- 2878
- Keene NH
- Send PM
Originally posted by Piece-it pete View PostBelts, hoses OK?
Pete"Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
