Hello,
I'm kinda getting frustrated. I cannot get the miss figured out.
I'm thinking about the FPR or O2 sensors even though I feel like it is electrical. I say electrical, because when i turn the lights on or use the electric seats, the car misses more.
So far I have thrown at it all new
distributor cap, rotor, egr valve, egr sensor, pcv valve, screen and grommet, IAC valve, TPS sensor,
new plugs, all the past week
PIP sensor, ECT sensor, Coil, TFI module in June and July.
Cold or hot it had a miss just before the shift points.
I had been able to drive it about 20 miles each day last week and yesterdayalso by using a light throttle, then just before the shift point let up on the gas so the car shifts and the RPMs are lower. light throttle the car would goup to 50 mph without a miss. I stayed on local streets, no freeways. With a Mid to heavy throttle it would miss. Heavy throttle would result in a bad miss and misfire.
Its frustrating because the car ran great until I took it to an electrical shop in July to fix/replace the alternator wiring harness. Upon return of the car to me on july 5th, it ran like crap. The shop did a smoke test and said/showed a lot of smoke coming from under the intake at the rear of the intake. It must have a vacum leak. They replaced the ECT sensor and said that took the engine light off, but did not clear up the miss. I found the vacum leak from the front of the intake and put the hose on. Still had the miss.
This past Labor Day I took it to another shop that had put the motor in 3 years ago. This time they said the same thing as they did before they replaced the motor.
They said the motor needed to be replaced. The valves were bad.
I do not trust their opinion and feel that they only want to rob me.
This weekend, I am going to check the fuel pressure,
try to clean the MAP sensor that is 1 year old,
remove the G Force chip I have been running the past year with no problems.
take off the intake and replace the gasket, maybe the FPR.
Now that the PCV valve has been replaced, I want to put a NOS throttle body on that I have.
Should I think about replacing the fuel injectors, they are 3 years old on being cleaned and rebuilt, if so which ones should I buy? LOPO or HO.
I have an HO long block in, that is running the HO firing order, with the LOPO intake and throttle body.
I have an NOS LOPO throttle body I want to put in.
1. Would it work ok with HO fuel injectors?
2. Do i need a stronger FPR and fuel pump to run the HO fuel injectors?
3. Will the LOPO fuel rails and fuel injector harness work?
I found a remanufactured HO engine on EBAY to put in.
It has a 3 year, 100,000 mile warranty. The seller has 100 percent feedback on lots of motors sold.
4. How hard is it to swap the remanufactured long block in?
I swapped engines and transmissions between 69-70 Mustangs with carbs and C-4 trans.
I am at the point i don't trust anyone to do my work for me.
If anyone puts another motor in, it will be me.
I'm sorry to ramble so much.
Thank you again,
Mike
Thank you again,
Mike
