After my recent breakdown in the '87 mgm, with a 302, it starts and runs fine. The fault, according to the firing indicator, was no spark, which returned after overnight sitting and cooling. How can I figure out what intermittently failed? I don't want to wait until I'm stranded again. My guess is coil, stator, pickup or TFI.
troubleshoot ignition '87 302
Pickup or TFI would
Be what I look at.
If you can press a cold lunch box freezer pack on it for a few min then it comes back to life when you start it, voila...
TFI , coil or pickup is one of the failure points.
Tauruses are notorious for TFI failure and Pickup failure that had the 3.0 Vulcan motor in the 80s and early 90s-Nick M.
Columbia, SC
TFI first, pickup second. The coils rarely die, but either of the distributor parts can and do fail in this way. The TFI probably goes more often than the pickup.86 Lincoln Town Car (Galactica).
Yep, only time I've ever had a problem with a coil was when I bought my 91 MGM. The post had corroded off after the car had been sitting down for 6+ years.Vic
Originally posted by TecNickal View PostPickup or TFI would
Be what I look at.
Tauruses are notorious for TFI failure and Pickup failure that had the 3.0 Vulcan motor in the 80s and early 90s1987 Grand Marquis LS two door, trying to get to the 60,000 mile mark.
