what about this to use for a carb convresion
    let me know what you think
    ewww that thing is nasty, it would take some serious cleanup to get it right, carb probably needs a rebuild also. It's in birdsboro where Scott lives though.
      Well if you want a 2 barrell...
      They did not make a Mustang 5.0 HO in 81. 81 was the 255 cubic inch engine. 82 was the first year for the 5.0 HO and it had a 2bbl carb.
      Seems kind of pricey for a 2bbl. You could probably score a factory 83-85 4bbl intake and a Holley 600 vacuum secondary that needs a rebuild for under $100 off ebay.
      Tom
        like this http://cgi.ebay.com/ebaymotors/83-MU...QQcmdZViewItem
          Thats pretty pricey for a stock HO intake. You could get a new Edelbrock Performer for about that price or less.
            If you want to go with a 2150 2bbl, that's fine, even though I did it I wouldn't suggest it. I got mine from Partsamerica.com for $125 IIRC. Gas mileage sucks with them. The CFM on them is also pretty low (I hear anywhere from 250-300 CFM) mine works good, but it gets pretty crappy gas mileage. I would go either 4bbl, or EFI.
              FYI-
              If for some reason you DO decide to go the 2bbl route, the 2150 will bolt directly onto your stock intake, you won't need a different intake.
                Get that mustang 4bbl intake (I run one) and a 500 cfm edelbrock carb.
                All you need with a stock CFI motor...
                  I still say 500 is too much carb on a cfi motor......
