Originally posted by 87vicFIVEO
View Post
NEED HELP!
Originally posted by 87vicFIVEO View PostAre Mark VII H.O. motors the most swapable to panthers??
And yes, 289 heads work on a 302. All Windsor smallblock heads can be interchanged with minor mods, 289, 302, 351. The 351w has larger head bolts, so you have to bore out the bolt holes on a 289/302 head to use on a 351, and use spacer bushings with a 351 head on a 302/289. 351c heads are not a direct swap onto a windsor engine block, but it can be done with the right modifications. Google for "clevor" engines, and you'll find all you want.86 Lincoln Town Car (Galactica).
351 heads aren't necessarily better. Some of the trucks used the same E7 head the HO engines use. When you get to after market stuff, you might get a good deal on some good Windsor head but the holes are only drilled to 7/16", simply drop them off at the machine shop and have them re-drilled, or do it yourself if you have a drill press and the proper means to set the head up where it will drill straight.86 Lincoln Town Car (Galactica).
Hello, me speaketh again....
Concerning the 289 heads: They are not intended to flow a buttload of air. They are intended to be a higher-velocity small head, that increases compression by a full point. Power through better compression, not bigger ports which kill off velocity, screwing up the stock computer, and killing off precious bottom end torque, which the 302 is not famous for to begin with. It won't run with regular unleaded, but with conservative timing, will run with premium.
Concerning the Lincoln MK7 AOD: I can make it work with the stock driveshaft, but it's an ugly modification, namely cutting off an inch of the driveshaft stub/yoke with a cutoff wheel, then cleaning the flash off of the end. It isn't pretty, but it works for me.
Originally posted by mrltd View Post289/302 use the same bore and bolt size. Nothing would have to be changed, except maybe pushrods due to length
Same intake, no changes required. 289 heads bolt right on. You must use the rockers for the 289 heads, and maybe you'll need to change the pushrods to get the valve geometry correct. Don't know on that point, but I do know the early heads do not use the same pedastal mount rockers. They use a stud mount rocker with a groove in the end for the valve stem. These are adjustable, like a Chevy motor. The tricky part is the valve seats. The 289 ended production in 1968, before unleaded fuel was in use. Older motors didn't have hardened valve seats, and using unleaded gas in them can burn the valve seats. I've heard some people say that since they were run on leaded fuel, it conditioned the seat area so that it will be OK, I've heard some say that it only happens if you run it hard, others will say imminent destruction. I don't know the correct answer, only that its something you should be aware of. FWIW, the trouble of finding a set of 40 year old heads is probably not worth it. Likely they'll need to be rebuilt, and by the time all is said and done, you could get something as good or better thats more modern and doesn't have the concern with the valve seats. If you can get a good deal on a set of 289 hipo heads, go for it, but personally I wouldn't go out of my way to spend a lot of money on them. You can get a modern set of E7 heads used for cheap, and have them done up for maybe 700 bucks. They'll do very well on a mild motor without costing a small fortune. GT40 iron heads are also not that expensive these days, can probably pick them up for 2-300. In stock form, a gt40 head blows an e7 out of the water and they do actually have more potential with the right port work.Last edited by gadget73; 06-11-2007, 03:11 AM.86 Lincoln Town Car (Galactica).
