Time to start spending money
    why aluminum heads? you guys like building smallblocks with the reliability of a taurus 3.8 v6?
      Aftermarket stuff isn't like those, dude...
      Not everything with an iron block and alum heads is junk...
        Originally posted by Pesty351 View Post
        Im going with the gt40x's for about 400 reasons, and I though just the H.O.'s 50 oz balance. I could be wrong..
        Interesting. Getting 'em for $400 less than a set of AFRs, perhaps?
        And yeah, I'm almost certain that all 302s after about 1980 or 1981 or so used the 50 oz. imbalance. Why that would be, who knows. I imagine you could check your original parts to be sure, if nothing else the casting number on the crank would tell you for sure what you need.
          AFR heads >>>>>>>> GT40X. Read some reviews/ look into some dyno tests. The AFR heads can pull out far more power than the GT40X. $400 isn't shit when it comes down to a significant power gain.
          Correct me if I am wrong; I believe I saw an ad where AFR claimed an additional 75 hp over the GT40X heads found on an FRPP crate engine. The engine was unchanged, except for the heads, and it pulled out an additional 75 hp. I believe I saw the ad in a MM&FF magazine.
          EDIT: Indeed; heres the article: http://airflowresearch.com/articles/...024/A24-P1.htm
          I believe the AFR heads are "that good"...
            Don't cheap out on cylinder heads.
            I could have easily paid 1800 bucks for a set of Edelcrock performer RPMS (which are still a good BBF cylinder head) but instead spent the money to get the Kaase heads for 2500.
            You get what you pay for, in terms of quality AND power. If you're spending that much, why not get the good stuff?
              In a day and age when people are spending $400 just for a cold-air intake, it's worth the difference for the SBF AFRs.
                Ok, I bought the tranny and goodies for $350. I've been looking more into the afr's since I got the tranny so cheap. I still need to know for sure what balance these motors are. Also if I went with the 185's what carb/intake/cam combo should I go with.
                1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
                  DaYuM good price!!
                    You sig reminded me. He has a hurst shifter on it too.
                        If you have a 351 in your car its 28oz balance....If its a 302 then its 50oz.
                          Ok thanks!
                            I picked up the tranny on sat. Now I just need the flywheel and clutch. Does anyone know what all the numbers on the tag mean.
                            I spy with my little eye something that starts with the letter "H"
                              I spy a Ford 1990 Mustang 5.0L V8 World Class T5. You got one of the better ones
                                Is that a Hurst shifter already installed?
