Originally posted by 87gtVIC
View Post
Yeah,I do know I need an 5.0 H.O. computer from a Mustang, but I've been told a Mark VII unit won't work. But is a computer swap all thats needed or will I still have these problems after the swap? And I've been told that in swapping the computer I'll also have to move several of the pins around ( but which pins?).
In fact I've been told a lot of things, here are just a few:
The Crown Vic is bank fired, the Crown Vic is not bank fired.
The Explorer does not have an H.O. firing order.
The Explorer does have an H.O. firing order.
You need all the wiring and computer from the Explorer.
You can only use Mustang computers and wiring, nothing else will work.
You must convert to mass air
You don't really need mass air
The cruise will no longer work.
The cruise will work, but the horn won't.
I've heard all this and a lot more! I do know the Explorer has a 65MM TB, #19 injectors and these were used.
Like I said, if this car will run without a mass air conversion and only with a
computer swap, how?
Thanks,
