couldn't you use the gasket as a guide to (CAREFULLY) Drill out a hole in your spacer for the EGR?
Another question I couldn't answer!
Bore The EGR Plate To 62mm Get An Explorer Throttle Body To EGR Gasket And Some (Right Stuff) Gasket Sealer,Take A Decent Sized Screwdriver And Put It In The And Drivesigpic351w .030, B303, 1.6 Roller Rockers, GT40P Heads Mild Port Job,351w Lightning Lower & Explorer Upper,65mm TB, Custom CAI, 24# Injectors, Adj FPR, 1/2 Phenolic Spacer, TPS Enhancer, Shift Kit, 2400 Stall, Hi-Rev Govenor, MMC Alcoa Driveshaft, 3.73 Trac Lok, Underdrive Pulleys, Electric Fan, MSD Street Fire Coil, MSD 6AL Ignition 12.35 @114 mph spinning through 1st gear
Put The Screwdriver Handle End In-In The Throttle Body To Wedge It Open. Wait An Hour To Allow Sealant To Cure. Remove The Screwdriver And Drive As NormalLast edited by gstak07; 09-07-2010, 12:00 AM.sigpic351w .030, B303, 1.6 Roller Rockers, GT40P Heads Mild Port Job,351w Lightning Lower & Explorer Upper,65mm TB, Custom CAI, 24# Injectors, Adj FPR, 1/2 Phenolic Spacer, TPS Enhancer, Shift Kit, 2400 Stall, Hi-Rev Govenor, MMC Alcoa Driveshaft, 3.73 Trac Lok, Underdrive Pulleys, Electric Fan, MSD Street Fire Coil, MSD 6AL Ignition 12.35 @114 mph spinning through 1st gear
