Another question I couldn't answer!
    Why is the lightning EGR out of the question exactly?
      I guess he means he cant find one, because it may well be the solution
        the egr spacer is your problem mostlikely......it wont seal......88grandmarq tried it several yrs ago and had problems........either locate a lightning egr spacer, or buy a mustang 65mm egr spacer and mod it for the throttle cable/tv cable bracket
          Why not a Lightning EGR? very hard to get/find and worth lt's weight in gold. I'm told?
          So it's either mod a 65MM Mustang EGR or just delete the ERG? I've got no problem deleting the EGR as long as I can still get past an emmissions inspection. The thermactor is already gone!!
          I'm I missing something? or does this sound right?
            visual or tailpipe test?
              tailpipe!!!!
                gotta keep the egr then......look at my 5.0 aero grand marquis thread, you can see how i modded a mustang egr spacer
                  I did look thanks!!
                  So, does that mean I can slide an H.O. spacer between the Explorer TB and
                  the Explorer Upper intake, with a modded throttle bracket and this will work?
                  Without having it bored out?
                  If so, great!! But if I don't know what the hell I'm talking about!
                  please stop me before it's too late!!!!!!!!!!!!
                  Isn't the H.O. spacer 55MM?, and does that make enough of a difference to
                  really matter? I need to get this thing running
                    the lopo spacer is 55mm and the mustang is 63mm. Yes you can use a H.O. spacer and modify your throttle cable bracket.
                    '90 LX 5.0 mustang
                    Big plans
                      go there
                      become a member and post a want ad for a stock egr spacer.
                      I did that and had one to the tune of 45 dollars shipped within a week.
                        OHHHHHHH, YES OF COURSE, IT"S SO SIMPLY, A CHILD COULD DO IT!!
                        NOW I SEE, THANKS
                          Now I'm being told that while I'm at it, it would be a good idea to use a spacer or gasket between the upper and lower GT40 intakes. One that will block that EGR hole thats right in the center?
                          Any truth to this or real need for it? :confused:
                            You're not using a gasket under your upper intake?
                              Yes, of course I'm using a gasket under the upper intake, but it's got the hole!
                              What I've been told is that this small hole in the middle of the lower intake is a
                              hole for EGR gasses, and should be blocked off. Since the CV already has it's
                              EGR bolted to the EGR spacer.
                              Is this correct? Is this hole in the lower intake for EGR gasses?
                              And should I block it off?
                              Since I've got to replace the EGR spacer, I can do this too at the sametime
                              if I have to.
                              This is upper/lower and TB from a 96 Explorer I'm working with.
                                Dont block it off.
