Why is the lightning EGR out of the question exactly?
Another question I couldn't answer!
Parts Car (Scrapped ) - Vicky - 1987 LTD Crown Victoria: 17x8 Gunmetal Gray Coys C-5 wheels, 235/55-17 Falken Ziex ZE-502 tires. 79 LTD Grille, Taillights, and Turn Signals, Blue LED Dash Lights, PI Rear Sway Bar, 140 MPH Speedometer, Dual Exhaust w/ Mustang Headers.
New Project: Vicky II - 1981 Ford LTD: 61,XXX miles, virtually rust free. Currently For Sale
I guess he means he cant find one, because it may well be the solutionPete ::::>>> resident LED addict and CFI defector LED bulb replacements
the egr spacer is your problem mostlikely......it wont seal......88grandmarq tried it several yrs ago and had problems........either locate a lightning egr spacer, or buy a mustang 65mm egr spacer and mod it for the throttle cable/tv cable bracket
Why not a Lightning EGR? very hard to get/find and worth lt's weight in gold. I'm told?
So it's either mod a 65MM Mustang EGR or just delete the ERG? I've got no problem deleting the EGR as long as I can still get past an emmissions inspection. The thermactor is already gone!!
I'm I missing something? or does this sound right?
visual or tailpipe test?Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
gotta keep the egr then......look at my 5.0 aero grand marquis thread, you can see how i modded a mustang egr spacer
Originally posted by Lincolnmania View Postgotta keep the egr then......look at my 5.0 aero grand marquis thread, you can see how i modded a mustang egr spacer
I did look thanks!!
So, does that mean I can slide an H.O. spacer between the Explorer TB and
the Explorer Upper intake, with a modded throttle bracket and this will work?
Without having it bored out?
If so, great!! But if I don't know what the hell I'm talking about!
please stop me before it's too late!!!!!!!!!!!!
Isn't the H.O. spacer 55MM?, and does that make enough of a difference to
really matter? I need to get this thing running
go there
become a member and post a want ad for a stock egr spacer.
I did that and had one to the tune of 45 dollars shipped within a week.Parts Car (Scrapped ) - Vicky - 1987 LTD Crown Victoria: 17x8 Gunmetal Gray Coys C-5 wheels, 235/55-17 Falken Ziex ZE-502 tires. 79 LTD Grille, Taillights, and Turn Signals, Blue LED Dash Lights, PI Rear Sway Bar, 140 MPH Speedometer, Dual Exhaust w/ Mustang Headers.
Originally posted by 1987cp View PostYou're not using a gasket under your upper intake?
Yes, of course I'm using a gasket under the upper intake, but it's got the hole!
What I've been told is that this small hole in the middle of the lower intake is a
hole for EGR gasses, and should be blocked off. Since the CV already has it's
EGR bolted to the EGR spacer.
Is this correct? Is this hole in the lower intake for EGR gasses?
And should I block it off?
Since I've got to replace the EGR spacer, I can do this too at the sametime
if I have to.
This is upper/lower and TB from a 96 Explorer I'm working with.
Dont block it off.~David~
