Originally posted by Mercracer
View Post
351W Swap time.
just add more mufflers
Originally posted by Mercracer View PostLooks like someone already did the work for me....$99 http://bcbroncos.com/store/product_i...oducts_id=1059
that looks evil, i wish i had a 351 efi lower and that it would work on my 302sigpic
That still looks tall, taller than my intake that doesn't have enough clearance for me to flip the air cleaner lid without hitting the hood.
Originally posted by johnunit View PostThat still looks tall, taller than my intake that doesn't have enough clearance for me to flip the air cleaner lid without hitting the hood.
Mercracer: As I found out, exhaust seems to shape the character of a car. Do you already have a performance-type exhaust on your Panther? If you do, you might be able to install glasspacks at the tailpipes to quiet down the car. If not, Dynomax has quite a few mufflers that could quiet down the beast. As far as appearance, perhaps befriend a rat rodder who knows how to spray a rusty-looking paint job on the aluminum heads and intake (as they would call patina).
Mrltd: My favorite comment was when we had a bone stock box next to mine (at a show with both hoods up) and this one guy said "they put ford racing plug wires on it and think it's a racecar" I peed in my pants a little laughing at that comment. Only if they knew.............or found out the hard way how fast your wagon is.
Originally posted by packman View PostMercracer: As I found out, exhaust seems to shape the character of a car. Do you already have a performance-type exhaust on your Panther? If you do, you might be able to install glasspacks at the tailpipes to quiet down the car. If not, Dynomax has quite a few mufflers that could quiet down the beast.
I ran the BC Broncos intake adapter on my 351...I wish I would have known about the Price intake adapters back then....the 351W EFI lower intake is a real turd and requires heavy porting for even lower performance applications. and if you don't have an upper plenum that's been cut open and heavily worked, you'll be shifting by 4000rpm and making peak torque below 3000...not too good if you plan on using a 4500rpm convertor. Done right, it's an okay setup for a daily driver, but it sounds like you're doing just a bit more than that.
I would say damn the consequences and run a victor jr to take full advantage of what sounds like it should be a sweet motor.
Good luck,
Don'85 CV coupe- 351W, T5-Z, FAST Ez-Efi, shorty headers, 2.5" duals with knock off flowmasters, 2.5" Impala tails, seriously worked GT-40 irons, Comp 265DEH cam, 1.7rr's, Mallory HyFire 6A, Taylor ThunderVolt 50 10.4mm wires, 75mm t/b, 3G alt swap, 140mph PI speedo, PI rear sway bar, '00 PI booster/MC, 95-97 front spindles, '99 front hub bearings/brakes, '92-'94 front upper control arms/ball-joints, 3.73's with rebuilt traction-lok, '09 PI rear disc swap, '96 Mustang GT wheels with 235/55R17's.
Originally posted by sick88tbird View PostI ran the BC Broncos intake adapter on my 351...I wish I would have known about the Price intake adapters back then....the 351W EFI lower intake is a real turd and requires heavy porting for even lower performance applications. and if you don't have an upper plenum that's been cut open and heavily worked, you'll be shifting by 4000rpm and making peak torque below 3000...not too good if you plan on using a 4500rpm convertor. Done right, it's an okay setup for a daily driver, but it sounds like you're doing just a bit more than that.
Good luck,
Don
I must have missed the nitrous part...lol. That intake set-up with some port work will produce freight-train like torque though.
Good luck,
