A remotely controlled distributor? lol.........
Mystery Distributor/ help an idiot get durasparked
Originally posted by Bowman85merc View PostCongrats, you just bought a California edition distributor
My cousin had the same thing on his bronco, and from what i recall, there should a brain box under the passenger or drivers seat to control it.
Its also non-adjustable distributor, hence why it was a Cali only thing, so you couldnt get more power than the factory intended, etc.
But yes, it would be best used as a doorstop/paper weight.
Wait, I also just remembered that the ignition control module was different, and his even had a crank sensor, which triggered the distributor. It also shouldnt have had any wires or vaccum lines going to the dist.
I forgot how it all worked, as it was a very stupid setup, so we just switched it over to an HEI and all is well.---1990 Lincon LSC., 5.0 H.O., 55,000 ORIG. miles, 3:73 Posi, Bullit rims, 3G alt., 2.5" full-back exhaust, Mark 8 elec. fan, Flowmaster mufflers. My DD
---1985 Grand Marquis 2-door., Fresh 5.0, slick-top, GT40P's, 1.7 RR's, FRPP headers, 3G alt., Weiand Stealth intake, 650 cfm holley, 2.5" side-exit exhaust, Mark 8 elec. fan, 3:55 Posi, Bucket seats, custom center console. My Toy
this didn't appear to have any connectors and had no evidence of ever having vacuum advance installed.
thats what he is saying. just a bare dizzy case.
crank trigger eh? Interesting. EEC3 used that with a Duraspark box. Not quite sure how it interfaced, but it did. I think it was a regular dspark box but it connected through the computer somehow, not direct to the crank trigger. I wonder if that Bronco wasn't EEC3 / feedback carb instead of EEC3/CFI. I know they made EEC IV carb engines. I've seen an F250 with an I6, a TFI module, and a 1bbl on it.Last edited by gadget73; 02-11-2011, 01:43 AM.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View Postcrank trigger eh? Interesting. EEC3 used that with a Duraspark box. Not quite sure how it interfaced, but it did. I think it was a regular dspark box but it connected through the computer somehow, not direct to the crank trigger. I wonder if that Bronco wasn't EEC3 / feedback carb instead of EEC3/CFI. I know they made EEC IV carb engines. I've seen an F250 with an I6, a TFI module, and a 1bbl on it.1988 MGM GS - Preferred Equipment Package 172A; InstaClear
1994 MGM GS Montigua
2002 Mustang GT Coupe
Originally posted by 86VickyLX View PostYea, EEC-III sucks. Crank position sensor with a distributor to control spark, what a crock of shit.1988 MGM GS - Preferred Equipment Package 172A; InstaClear
no I haven't looked at your Conti, but I've seen EEC3 in action before. It works just fine when it works. Its like EEC4 cfi really. I've driven some 84-85 models that ran like a watch. I've driven those same cars that ran like absolute shit though.86 Lincoln Town Car (Galactica).
It was kind of ahead of its time. That system came back in later cars with the crank trigger and the ECM driven spark control. Maybe it didn't quite work out as intended in the early version but honestly you don't hear about that many ignition system problems with eec3. The crank triggers got funky from being in a bad spot where oil leaked into them and stuff, but its not like they were baking parts at an abnormal rate. I'd go so far as to say the TFI module is not really any more reliable.86 Lincoln Town Car (Galactica).
Considering the stock ones are capable of lasting past the 200k point, I really don't consider the tfi ignition system to be unreliable at all. I was just making the case that the eec3 setup is not really any more unreliable than TFI or regular old Duraspark. I bet points ignitions shit out way more often. Having owned breaker point cars, and worked on a lot of points fired boats, I can tell you they definitely need a lot more TLC than electronic ignitions of any sort do.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostConsidering the stock ones are capable of lasting past the 200k point, I really don't consider the tfi ignition system to be unreliable at all. I was just making the case that the eec3 setup is not really any more unreliable than TFI or regular old Duraspark. I bet points ignitions shit out way more often. Having owned breaker point cars, and worked on a lot of points fired boats, I can tell you they definitely need a lot more TLC than electronic ignitions of any sort do.
