Yes. Pictures Please! I thought about extending my rod (ha ha ha). But I couldn't figure how to do it.
Mark VI "Edelbrock Performer" Carb & Intake Conversion.
Isn't one end of the TV rod threaded? If I'm remembering that right, it might be easy to extend it with a bit of allthread and a spacer nut. When I extended my C4 kickdown rod, I just used a nut and bolt and a flat piece of metal with two holes drilled in it.2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by 1987cp View PostIsn't one end of the TV rod threaded? If I'm remembering that right, it might be easy to extend it with a bit of allthread and a spacer nut. When I extended my C4 kickdown rod, I just used a nut and bolt and a flat piece of metal with two holes drilled in it.1980 Lincoln Mark VI - Now With New & Improved 4.6L Modular Power!
my tv rod is just flat at the end with an eyelet too, no thread.
Here's some pics of the install.
First I cut about 4 1/4" off of the outer case to get the best length. To get the right amount of throw you have to use the TV corrector, without it the lever on the trans will bottom out before full throttle. Then I took the slack out of the cable. the measurement I got between the the throttle & the cable bracket is about 4 1/2". Hopefully this will help anybody trying to do this setup.1980 Lincoln Mark VI - Now With New & Improved 4.6L Modular Power!
After that you have to let the car warm up to operating temperature. Then take the little tool that comes with the TV cable & insert it as shown. Then check the pressure gauge with the car in neutral (not park) make sure it reads 33 to 35 Psi. Then pull out the tool & make sure it reads 0 Psi(zero psi). Disconnect everything & road test. Every gear should shift fine. If not try to adjust again.1980 Lincoln Mark VI - Now With New & Improved 4.6L Modular Power!
So now that you've had an opportunity to drive it a bit more. How does it feel? More power?Owner of the only known 5 speed box wagon with a lift kit.
Axle codes
Open/Lock/Ratio #
G / H / 2.26
B / C / 2.47
8 / M / 2.73
7 / - / 3.07
Y / Z / 3.08
4 / D / 3.42
F / R / 3.45
5 / E / 3.27
6 / W / 3.73
2 / K / 3.55
A / - / 3.63
J / - / 3.85
Nice pictures.
You may notice that the spring on the transmission end of the cable (that returns the lever when the throttle is let up) is somewhat lazy. Most people on this forum have removed that and added an external spring to return the lever on the transmission.
I am going to be putting my stuff together shortly, and I will also be testing the TV pressure with a gauge.**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
Originally posted by GoodSamaritan View PostSo now that you've had an opportunity to drive it a bit more. How does it feel? More power?1980 Lincoln Mark VI - Now With New & Improved 4.6L Modular Power!
I am going to be putting my stuff together shortly, and I will also be testing the TV pressure with a gauge.1980 Lincoln Mark VI - Now With New & Improved 4.6L Modular Power!
