Cooling issues? T-stat mod.
I've drilled one small hole to help bleed air. Some newer thermotstats have a built in little check ball for that purpose.**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
hell no!
might as well take the thing out
I only use OEM and call it a fucking day!
I've used those with the 'jiggle valve' (bit of crimped metal in the hole. It does seem to make a difference. Mostly I notice that as the temp climbs, that peak that occurs with a conventional stat before it opens is not as big, smaller temperature swing overall.
Couple days ago I gutted the thermostat in my truck (see previous post of potential head gasket failure) and now my temp guage barely rises, if at all, over my commute. Certainly not a recommended mod, and certainly not that hodge podge of holes posted above.
Alex.
the thermostat sets the minimum operating temperature. Thats it. If its letting the engine overheat its usually either sticking or it just doesn't open far enough to allow for proper coolant flow. Most of the time overheating is a clogged radiator or bad fan clutch or some other problem. A little hole to bleed air is one thing, but big holes pretty much just bypass it and cause overly slow warmups. Running the engine too cold actually makes things wear faster too.86 Lincoln Town Car (Galactica).
The holes defeat the purpose of what the thermostat is supposed to do. May as well just remove it. Engines are made to run most efficient when they are warmed up. With this setup, you may never get there.Nick
Past: 1967 Continental convertible, 1987 TC Cartier, 1996 TC DAE & Signature, 2002 LS V8, 2006 Zephyr, 2010 MKZ AWD, and many more.....
Current: 2010 F-150 Platinum Supercrew 4x4
Wanted: 1967 or 1969 Contnential sedan
Only in my dreams: A Continental Mark II
Originally posted by LithiumCobalt View PostThe holes defeat the purpose of what the thermostat is supposed to do. May as well just remove it. Engines are made to run most efficient when they are warmed up. With this setup, you may never get there.
Sent from my '85 Lincolin Town CarUsing Tapatalk
if you drill... only 1 hole and keep it small. you shouldn't even need a hole in the t-stat except for the tiny ass one that comes in the replacement buggers to help burp the system.
