Hi. My car is an 89 Grand Marquis that I converted to HO. Computer is a speed density unit from a Mark VII. HO cam, intake, TB. 19 lb injectors.
For the past several months it's had a problem with the engine cutting out. No real pattern to it in terms of temperature, driving conditions, etc. Sometimes it was at low cruising speed, sometimes motoring down the highway. Never under hard acceleration. I could pretty much always mash the gas pedal and sorta power through it. I would occasionally check and/or clear the codes. The only codes I consistently got were 41 and 91. However along the way, I did replace the ignition wires, cap, rotor, EGR position sensor and recently the TPS. Maybe 2-3 times during this period the engine died at a stoplight.
I got suspicious of the fuel pump, because of the 41/91, and because when the problem would occur it felt like it was running out of gas. Also, one day last week it was cutting out and I noticed the fuel pump was extra extra loud. It was a stock replacement pump listed for the Grand Marquis. I put it in a couple years ago. This weekend I replaced it with a pump listed for an 89 Mustang. Per the specs listed by O'Reilly, the Merc pump is 13 gph and the Mustang one is 18 gph.
It is driving better. Idles better, revs up quicker, seems to have more torque. So far I don't think it has cut out while cruising. But yesterday and today, both while on the way home from work, it died repeatedly at stop lights. This was with a well warmed-up engine after 30 minutes or so of driving. It was really running like crap. Started right back up every time and by the time I got home it was running smoothly again.
I wish I had, but I did not clear the codes when I did the fuel pump job. Yesterday I checked the codes and got the following:
KOEO
91 41 54 31
KOER
41 91
I did the Self Test and got 9..... 9....., which I assume is 90 (PASS).
The EVP is basically brand new. The ACT is maybe 4 years old.
Any recommendations?
KOEO
91 41 54 31
KOER
41 91
