underdrive pulley set
    Any site where they sell under drive pulleys for a 1990 Grand Marquis?
    It's the crank pulley only. Here's a thread with some actual user experience: http://www.grandmarq.net/vb/showthre...T-HAVE-for-HOs
      It doesn't do awesome things for AC performance in traffic. Yesterday driving around it was 85 outside, I had 36 degrees at the vents while driving. Stopped that got up to 58 degrees.
        Dang read that thread, if no power gain , then I'll save my money.
        Sent from my Z956 using Tapatalk
          Its much more useful with an HO engine that will spin some rpm. On the stock engine it won't do much for you.
            Hmm I see, well thank you for the info
              If it affects A/C performance i'm out. Too goddamn hot here to compromise that. I'll just add more horsepower and ignore the noise.
                If I can lay my hands on a stock set of pullies and belts, I may do a back to back comparison of AC performance. I don't know how much is the compressor spinning less, and how much is the fan. If its mostly fan, thats easy to fix with an electric aux fan. Its also possible I'm just dealing with the usual R134a sucking in traffic symptoms that would be fixed with a better condenser. I get a solid 40-45 degree drop while driving, but its closer to a 20 degree drop when stopped.
                It would also be worth actually determining what the pulley ratios are. I don't honestly know. That would tell me exactly how much slower the compressor is running. Absolute worst case, I could make myself an underdrive that is larger than the ASP one but smaller than the stock one, or make a custom one that makes the AC run close to stock speed while underdriving the other. It would be time consuming but not impossible. If I do it, I'm not making a second one though so you people are on your own
                The problem with it is not just noise. At high RPM it spins that water pump so fast that it makes enough pressure in the cooling system to blow the heater core. With a stock motor that shifts at 4200 rpm, its a lot less of a concern but if you add another 1000 to that you've got problems. Restrictors in the line will help but may not entirely fix it. You also risk damaging the other accessories that were never intended to run at screaming speeds.
                  Good food for thought gadgo, just bothers me that a fuckin' pulley costs 150 bucks. I got a whole set of underdrive pullies with an SFI-approved balancer for my '98 for the same price. Stupid boxes...
                    I was planning on getting new pulleys for my box so I considered underdrives but I think I'll just stick with stock new pulleys. My car shift at 4500 when I punch it on 1st and 3rd gear.
                      Supply and demand. One place makes it, and how few people actually own one? Wouldn't half surprise me if they either make them to order or do maybe 10 at a shot when they need to. If you had the CNC program it wouldn't be a hard part to knock out a short run of. Its a single application thing too, the one for your 98 probably also works on Mustangs and other vehicles with the 4.6.
                        Thain, are you saying that the underdrive pully will make the water pump spin even faster? I am debating on purchasing one of these underdrives but the belt search (yes, I know you have supplied belt numbers and that it should help) and already having a couple things go on this motors life kinda deter me from trying things that will put even more strain on her.
                          no, it spins the water pump and AC compressor slower. THe stock pulley makes the water pump spin like mad, especially at high rpm.
                          Somewhere along the way I changed my AC belt to a shorter one. If you need it I'll get the numbers for you. The one I was using initially was a bit too long and after some time it stretched enough that the sides would hit, and it started jumping off the AC compressor.
                            Ill listen to anything info you may give. Last I read youoriginally went with: underdrive pully belts 48 1/2" (5060485) on the alternator side, and a 53 3/4" (5060538) on the AC side
                            prefer 49-49 1/2" on ac side
                            I think this was what you wrote ages back.
                            I think I will pick one up now.....
                            I have an aftermarket tensioner that may mess with belt size comparisons....
                              Original:
                              New one:
                              To be honest though there is quite a but of throw on the tensioner available so it may be a non issue.
