I finally understand why you folks install those crazy rate springs: it forces you to drive slower for fear of your teeth coming out. I swapped out my 98-02 Grand Marq 710 in/lb springs for a set of HD sedan coils, 433 in/lb and the improvement in ride was just amazing. It dropped the front end 3/4" to stock levels, softened the ride by vast amounts, and made the steering more stable because the suspension was taking up the crappy roads. I came home tonight and had an extremely difficult time keeping the car under 75.
I also realize just how bad the rear control arm bushings are, and how badly I need body mounts. The front fenders bounce on uneven road because the mounts are all but gone now. Must find a source for body mounts and replace the rear lower control arm bushings and it should be good as new. 433 in/lb FTW, screw those stiff POS springs.
