Pulled a shock off this morning to do some measurements. Found that the shock is dead, it didn't extend after compression. The other thing I found is that there isn't much travel from static ride hieght to full extension. Ride hieght is 19", full extension is ~20.75. So less than 2" of travel. And we all know that the car has more body roll than that, even with my modifications. I think it's safe to say that it's a signifigant contributor to my oversteer.
So, now I need to decide on replacements. Mustang and fox bodies use similar dimension shocks. So, afco 1043, a few koni's, and other street stock shocks would fit. the problem with all of them will be the length at ride hieght. A 1-2" extension on the upper stud would probably help me out and get the ride hieght to be closer to the mid point of shock travel.
