ah! I thought it was the forward hole that gets drilled... d'oh... Glad you have new arms on the way
Installing a rear PI sway bar
all the control arms I have seen, the rear hole was already drilled. on the 3-4 cars I have drilled holes in the LCA, the rear hole was there and I drilled the FRONT hole.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
Originally posted by 88grandmarq View Postall the control arms I have seen, the rear hole was already drilled. on the 3-4 cars I have drilled holes in the LCA, the rear hole was there and I drilled the FRONT hole.
And it looped around the shock just like in these pics:
I did some searches a little while back on here and it was mentioned in a thread that it's the rear most hole that gets drilled(the one closest to the rear bumper).
.......there was just no way for me to make the mistake of drilling the wrong holes, the bar would never have fit any other way on my car, when I did the install I lined it up both ways to be sure.Last edited by mercuryhead; 04-16-2008, 07:09 PM.
At this point, who cares. You got the replacement arms with both holes drilled and the lip bent for the sway bar install, so its sort of a moot point.
If I might make a suggestion, replace the bushings in the lower control arms before you install them. The ones in there probably aren't like they were 20 years ago.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostAt this point, who cares. You got the replacement arms with both holes drilled and the lip bent for the sway bar install, so its sort of a moot point.
Im gonna see how the old bushings in the arms are....the guy I bought them from says they are still good + I bet the ones in my arms are good, Ive got only 79K always garaged miles. I know age plays a major part in rubber, but Im low on cash right now, so I'll have to make due with what I have.Last edited by mercuryhead; 04-19-2008, 12:27 PM.
nothin wrong with that... Im re-using the used upper ball joints and hubs for my big brake swap... they feel fine and they arent that hard to replace after the fact.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
If you're not installing new ones, don't bother pulling the ones out of the current arms. Probably mess the bushings up trying to re-install them more than if you just ran what comes in the police car arms. Just make sure they're not obviously screwed, if the rubber is heavily cracked and the hole around the metal insert is egged, the bushings are toast.
Also, the lowers aren't the annoying ones to change. Both of those bushings are in the arms and you can do them on the bench. Upper arms are more difficult to access, and two of the bushings press into the rear housing itself.86 Lincoln Town Car (Galactica).
"In science it is either physics or stamp collecting." - Ernest Rutherford
- Oct 2009
- 2878
- Keene NH
- Send PM
Hmm Okay so I am going to be doing this on my 91, will I have the same problem with clearance issues? also if someone could tell me how to figure out the placement that would be great too, or maybe more pics. Thanks for any help."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
- Oct 2009
- 2878
- Keene NH
- Send PM
Im going to take some parts from a 90 PI tomorrow, I can check those if nobody else does."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
What size/type of bolts etc do I need to install the rear bar. I have a p72 but I have no idea if I have 2 holes in the LCAs or not. Drillng one per side isn't a problem.
I have no idea what mounting hardware I need though.
Thanks!sigpic
I skimmed right on past it on page 2. mercuryhead posted it...d'oh.sigpic
I Got My P.I. Sway Bars Off Of A 1990 CV In Augusta Georgia At (Pull A Part) You Stand A Better Chance Of Finding Old P.I. Parts In The South Or In Rural Areas Because They Are Still In Use In Many Rural Places If Youre In The Northeast Try West Virginia Or Ohio There Are Many 140mph Speedometers To Be Salvaged Also I Got 2 140 MPH Speedometers,2 Power Steering Coolers,2 Oil Coolers And 4 P.I. Sway Bars For $110 Tax Included So The Parts Are Out There And There Were 3 Old Box P.I.s There This Was 4 Months AgoLast edited by gstak07; 09-06-2010, 08:18 PM.sigpic351w .030, B303, 1.6 Roller Rockers, GT40P Heads Mild Port Job,351w Lightning Lower & Explorer Upper,65mm TB, Custom CAI, 24# Injectors, Adj FPR, 1/2 Phenolic Spacer, TPS Enhancer, Shift Kit, 2400 Stall, Hi-Rev Govenor, MMC Alcoa Driveshaft, 3.73 Trac Lok, Underdrive Pulleys, Electric Fan, MSD Street Fire Coil, MSD 6AL Ignition 12.35 @114 mph spinning through 1st gear
Originally posted by gstak07 View PostI Got My P.I. Sway Bars Off Of A 1990 CV In Augusta Georgia At (Pull A Part) You Stand A Better Chance Of Finding Old P.I. Parts In The South Or In Rural Areas Because They Are Still In Use In Many Rural Places If Youre In The Northeast Try West Virginia Or Ohio There Are Many 140mph Speedometers To Be Salvaged Also I Got 2 140 MPH Speedometers,2 Power Steering Coolers,2 Oil Coolers And 4 P.I. Sway Bars For $110 Tax Included So The Parts Are Out There And There Were 3 Old Box P.I.s There This Was 4 Months Ago
Find any tranny coolers?~David~
Buy That New 25 Buckssigpic351w .030, B303, 1.6 Roller Rockers, GT40P Heads Mild Port Job,351w Lightning Lower & Explorer Upper,65mm TB, Custom CAI, 24# Injectors, Adj FPR, 1/2 Phenolic Spacer, TPS Enhancer, Shift Kit, 2400 Stall, Hi-Rev Govenor, MMC Alcoa Driveshaft, 3.73 Trac Lok, Underdrive Pulleys, Electric Fan, MSD Street Fire Coil, MSD 6AL Ignition 12.35 @114 mph spinning through 1st gear
