I will be starting my complete rear end swap this weekend. I want rear disks, limited slip, and 3.73 gears for my below listed vehicle. I don’t want to mess with the rear end that’s currently in my car now because I want to keep driving it until the very day of the transplant. I’m going to pull the rear end from a donor car from the junk yard. I will purchase new aftermarket 3.73 gears and have it all rebuilt and put together by a shop. I will do the swap in my garage when the rear end is done and I get it home.
Now, I have made a CHECK LIST to take with me to the junk yard so I can pull the correct rear end. I was going to scan it for all to see, but I’m lazy, so I will just type it out. Please look it over and see if I missed anything. Please advise if anyone has any comments or concerns. Here it is:
1. Find any 1992-1997 vehicle with a panther platform.
2. Make sure it has rear disks.
3. Check the door sticker and find the code for limited slip (m,z,e,or k)
regardless of gear ratio since I’m putting the aftermarket 3.73's in.
4. Check the metal axle tag. Make sure the is an "L" in the
ratio (ie. 3L08 not 3.08. Again regardless of ratio.)
5. Make sure it’s an 8.8 on the axle tag.
6. Take all control arms and sway bar if any. This is so I can clean them up
and put some poly bushings in them.
Anything I should keep in mind about the driveshaft??
**** I know there is more stuff I have to do to the brake lines and stuff, but
this list is ONLY my guide to find the correct rear end. I will deal with the rest later at the house.
Thanks
Thanks
