Front end shake, pretty bad at low speeds. It used to only used be a small vibration when breaking, so i figured the rotors were just warped and that id replace them when i got new brakes. Recently it has gotten worse, the car shakes terrible back and forth and low speeds without me pushing the brakes. I was thinking it could be a lose bearing or just need a front end alignment, IIRC I also read that old tires and cause a car to do that. Let me know experts.
Shakey shakey
Check front wheel bearings, make sure they're not loose.
Tires balanced properly?Originally posted by gadget73There is nothing more permanent than a temporary fix.
Tire imbalance doesn't show itself at low speeds - I'd guess you have a tire with a split belt bulging out. Run your hand over all your tires' tread, I bet you will feel one with a bulge.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
new tires time!
If the tires are 20 years old, they're at least 15 years overdue for replacement.86 Lincoln Town Car (Galactica).
get new tires mang.......i told you they were scary looking
Your lucky one hasn't blown out yet. Get new ones yesterday.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
A blown tire can do serious cosmetic damage to your car fyi.
And be careful rubbing/feeling the tire, if belts are exposed they can stab the heck out of you (personal doofus experience).
PeteOriginally posted by gadget73For other types of inquiry, more information is required. Please press 4 to speak to a representative who can help you with your question. This call may be monitored for quality assurance purposes.
Originally posted by Piece-it pete View PostA blown tire can do serious cosmetic damage to your car fyi.
Pete
the belts fly apart when the get old, no warning......i had one blow apart on the motorhome, looked fine when i left the campground, 200 miles down the road on the way home it blew in the most inconvenient spot possible, and scratched the fiberglass up pretty good
I still wake up screaming occasionally after having gone through the "great" Firestone tire debacle back in the 90's I can remember spending many 8 hour days doing nothing but changing out those black rings of rubbery death. Disintegrating tires are no fun.Current stable:
1984 Ford LTD Crown Vic
1994 GMC Jimmy 4x4
1972 Volkswagen Camper Bus
2000 Ford Windstar
Originally posted by insomniac391 View Postthe tires are 20 years old lol.Originally posted by gadget73There is nothing more permanent than a temporary fix.
