Since the advice for using the P71 tailhousing and aluminum driveshaft on a whale is to go ahead and use it with the the factory short tailshaft 4R70W, I have concluded that I can do the same on an AOD in a box. The driveshaft length of the 97+ aluminum and MMC driveshafts looks at a quick glance to be the same as a 90-91 GM with an aluminum driveshaft. (I was wrong.. see below)
I am going to go a step further. I am going to take a 89-93 2wd Truck AOD which has the long tailhousing and 7 spline speedo gear and use it in my box with the substitution of the P71 4R70W tailhousing.
Obviously I am going to measure and mock it up before I would try running it this way.
