Does anyone know where I can get poly isolators for a 1988 Town Car? I can't find them for Vics at all. I did get a ton of hits for Mustang isolators... does anyone know if those will work? According to Rock Auto, rubber isolators for my Lincoln are 2.13 inch ID x 3.88 inch OD. If someone had a Fox-body isolator kicking around, or something, could they measure it and see if it's close enough to use?
Polyurethane coil spring isolators?
front or rear? Front ones come from ES with the poly kits for 92-97 Vics. I imagine you can get those seperate.86 Lincoln Town Car (Galactica).
Rear uses isolators? Oh, wait, there are tiny little squished things on one end or the other, aren't there ....
Wouldn't ES entries at Summit have the dimensions listed? Napaonline is sometimes helpful for this sort of cross-referencing too, and occasionally even AutoZone.com has helped me me figure junk out.2012 Mazda5 Touring | Finally working on the LTD again!
never seen rear poly ones. I've always used regular rubber ones because I could get them anywhere.86 Lincoln Town Car (Galactica).
really wish i would have known this a bout a week ago, i just swapped the stock springs in from limo springs. i ve seen mustang springs they arnt that much duff from panther springs just shorter89 townie, mild exhuast up grades, soon to have loud ass stereo....
I'm sure the spring diameter is pretty common and aftermarket ones are there, don't ask me where though lolPete ::::>>> resident LED addict and CFI defector LED bulb replacements
I've got it written down here somewhere, but I think it was 1994 Caprice rear spring isolators where the correct dimensions.
Hop onto the energy suspension site and you'll be able to get the dimensions of them and compare to stock size.
Alex.
1971-1996 Caprice.
Napa has regular rubber isolators now.
Front: 2749721 $7.41 each. (last time I got them, its a pack of 4 from Ford for something around $15)
Rear: 2749140 $unknown 10 pack. (Store only item, no online pricing, seems napa does that with all bulk parts packs) (Don't remember Fords pricing, or pack quantity (it was either single or two pack. Like my Energy Suspension part number, its in a location that should be easy to find).
Alex.
Originally posted by GM_Guy View Posthttp://www.energysuspension.com
http://www.google.com along with a bit of comparative searching will get your answers.
Alex.
