Hi!
I think I'd noticed something like this in months past, but it seems to be a bit more frequent.
I have a 1990 GM wagon with 123,000 miles on it. When I bought it, at 109,000, the seller had rebuild the transmission at 103,000.
There's a shift flare usually coasting up a hill between 20 and 40mph, when I even very gently tap the gas, as if it wants to downshift, but then decides not to.
If I hit the gas harder, it does downshift, and hard. But if I try to maintain speed in the present gear, it will hesitate-- again, as if it's thinking about downshifting and then doesn't and goes back to the present gear.
But more recently, I have trouble --possibly on cold starts, as it was both this morning and again leaving work-- moving in first gear? Now, once I'm in gear, I should be IN GEAR, so unlike say my 2nd-3rd shift (I'm guessing), there's no question about hovering in between gears. It's in first. End of story.
So why, as I drove up a slight slope and stopped at a stop sign to make a left turn, when I went to make that turn, did I rev to 3000rpm doing nothing for as long as 2 seconds before I got any torque at the rear wheels?
I checked when I got home: transmission fluid is clean as new, and if anything possibly overfull by the smallest margin (1/8" past the hatches). TV cable hooked up at the throttle.
fwiw, I had a coworker adjust the tension a little higher to move the shift points up. Maybe this pretension is why I'm getting that "going uphill @20-40mph" flare, and I need to loosen it?
I'm not sure it as readily explains no torque transfer in 1st gear pulling away from a stop sign?
