ES poly front bushings ('92-'97)
    police upper arms or civilian upper arms?
      I'm going today to get civilian arms. Would the pi be better or easier to get bushings for?
        what arms do you have 02?
        2of the big brake conversions i have done i used 98-02 upper arms and ball joints.......4.3153 is the set u need if you are using 96-02 upper arms
          If I use 02 upper arms what dos I use to bolt them to the chassis since they don't work like the earlier models?
            use your original control arm shafts......you will have to grind the shaft a little bit to fit thru the metal sleeves after you burn the rubber bushings out
            or you can harvest some 92-94 upper control arms, but heck use what you got......the 96-02 upper ball joints are cheaper
            i always leave 95 out because that was the suspension changeover year.....i'm not sure what date they changed over in 95
              Ok cool so I have 02 upper arm, spindel, and caliper. I can use the 4.3153 bushing for the upper and original bottom control arm. Correct? Should I take the '02 sway bar or anything else off this car while in here?
                Also can I use the 02 lincolns lower control arm? Just to clean up and paint cause the oringinal one looks like crap.
                  lower arms are the same from 79-02, so no problem there. The only difference in the bushing sets is the ones included for the upper arm.
                  You can pull the later model bar, but you need later model endlinks to make it work. We did that on something, and it handled very nicely from what I remember. Don't recall which bar was used though, but I'm thinking it was a larger hollow bar from a taxi.
                    one of the bushings on the 98-02 lower arm is different, but it will bolt up. problem is you would need two bushing kits.......a 92-97 kit (btw energy suspensions listing is incorrect) and a 98-02 kit
                    me thinks i need to have a big brake conversion podcast or something
                        Lol a podcast would sure help me. This is my daily driver so I get one chance to get this right. So I guess my final concern is if I use the 02 upper And lower control arm then part number 4.3153 will cover all the bushings I need, right?
                          02 uppers.......79-94 lowers use 4.3153 yes
                            Lol a podcast would help me. This is my daily driver so I have very little room for error. I guess my final question is if I use 02 upper and lower control arms then for the poly bushing ES part 4.3153 will be all I need, right?
                              SORT I didn't know there was a page 3 thought it didn't post
                                Ok so if that part number 4.3153 is for the lower 79-94 what do I do for my 02 arms is there a part number fo those.
