that part number is lower arm bushings, upper arm bushings, and coil spring insulators
ES poly front bushings ('92-'97)
because the lower control arms use two different bushings on each side from 79-94
energysuspensionparts.com, I think that's the good place to buy the stuff.
One place was good, one place was assholes. I don't remember where I bought my stuff from, Scott knows though.
I googled it, yeah, energysuspensionparts.com, suspension.com were the a-holes..Builder/Owner of Badass Panther Wagons
gotta save the outer sleeves......just burn out the rubber
i get my bushings from energysuspensionparts.com
can also get the bushings at autozone, but they charge more
yea you need to use the washers on the upper arms........clean them up real good, and also get new upper control arm nuts
