nope
ES poly front bushings ('92-'97)
doh!
Originally posted by gadget73 View Post90s style uppers requires a different front spindle. 92-94 has the same size brakes, but with a hat rotor instead of a hub rotor. No point in doing that honestly, if you're changing upper arms and spindles you may as well put big brakes on it.
If you use the poly bushings, you can just torch the rubber out and shove new ones in. Vastly easier than pressing that stuff apart. The arm also won't try and fold in half on you, which is not especially fun.
My neighbor helped with changing the bushings out, he set the ball joint press up, hit the sleeve with a torch and slid the bushings out (on the lowers). Certainly easier to just burn'em out completely though I'm sure.
PeteOriginally posted by gadget73For other types of inquiry, more information is required. Please press 4 to speak to a representative who can help you with your question. This call may be monitored for quality assurance purposes.
