Bad Tie Rod Video. Opinions?
    Here is a video of my drivers outter tie rod. Does the up and down motion you see here mean it's bad?
    87' Lincoln Town Car Stars + Stripes. Explorer GT40P, Anderson B31 Cam, Shorty Headers, FRPP 1.6 Rockers, A9L, Sn95 T5 Trans, 3:55 Limited Slip, GNX Rear Springs, LSC Turbines, 1.5 wheelspacers, Full Custom Dual 2.5/Flowmasters, 00 P71 Airtube, 19lb calibrated Maf, Summit Alum Radiator, King Cobra Clutch, Short throw Shfter, Energy Susp Trans Mount,
    Mods to come: Big Brake/Poly Front Swap, PI Front Swaybar, Addco 650 Rear Swaybar, Boxed Upper Rear Control Arms, 351/Alum Heads, FRPP Valve Covers,
    I could not really see that.
      it shouldn't do that but the more critical play is side to side. Rock the steering wheel and see if the tie rod moves before it pulls the spindle along with it. I'm betting it does, which means its done.
        It's junk.
        Assume all other joints are as well (the 3 other rod ends and all 4 ball joints, as well as the idler and pitman arms) until you know otherwise.
          thats scary!
          i would start ordering parts and replace everything
            The tie rod also has side to side play, but I didnt get it in the video while up on the lift. The mechanic was being a douchegrip. 2 months ago I slammed a crater in the ground caused by a construction company and began to have a knock in the right front. I thought it screwed up the rf shock. After inspection the only thing we could find was the bad tie rod and a junk pitman arm. I have to send that video in to their insurance company and theyre hopefully gonna cover the tie rod.
              E.S. Bushings, big brake swap, tie rods, sway bar, springs. All happening at the same time within the next couple weeks.
                That thing is handle nice! Which springs are you going with?
                  Hey Pantera. I've got wagon cargo coils from autozone out back, and I will run cut p71 springs up front.
                    When you by tie rods, do you buy just the ends, or the hole kitten kaboddle?
                    I was going to get four of this
                    ACDELCO Part # 45A0210 {#88910044}
                    ROD,STRG LNKG OTR TIE -
                    and for the U-joint I was going to get this
                    MOOG/PRECISION Part # 354 Premium
                    At Transmission; w/3-7/8" O.D. Yoke; w/Towing Option; w/1-1/16" O.D. Bearings
                    At Rear Axle; w/3-7/8" O.D. Yoke; w/Towing Option; w/1-1/16" O.D. Bearings
                    (((((But I noticed two sizes for U-joints for the same car. What gives?
                    -1973 Volkswagen Bus Westy
                    -1986 Honda Magna 700cc
                    -2011 Subaru Outback
                      depends on what's bad for the tie rods... typically it's just the end joint.
                      U joints have two options... the larger is for tow-package cars usually (or police/performance). Most civilian cars have the smaller one. Always best to know which one you need before purchasing by measuring.
                        Ok, I gotcha, so measure the diameter of the U-joint>
                          here's a page that shows where to measure: http://www.actionmachineinc.com/ujoi...ringguide.aspx
                            Normally just the ends are bad, but if the sleeve is old, it may not let go easily. I've replaced mine for that reason. Sleeve is typically about 20 bucks, so if you have to replace both ends, it doesn't really make sense to me to fight with the rusty sleeve.
                              I see, interesting. How would you diagnose a bad tie rod?
