Hello,
I'm gonna start a front brake job today since a cold front came thru and dropped our temperature to 95 degrees. I bought the Eline slotted rotors with hubs and studs, new inner and outer wheel bearings, grease seals and disc pads. Is there a best way to pack the bearings with grease? I used to do it by packing the grease in the bearing by the palm of the hand. How tight should I tighten the nut on the spindle holding the bearings in place?
I Thank You as always,
Mike
Mike
