My '90 CV is leaking PS fluid pretty steadily. Tried using some Lucasoil with stop-leak, but did nothing. I'm thinking it's time for a rebuild. The kit's $10 at my local Advance Auto. Is it worth it to try and rebuild? And how difficult can I expect it to be? Thanks!
Rebuilding power steering pump?
It might work. I did rebuild mine 4 years ago and it still working fine.“Cars are the only thing on earth that will beat you, break you, make you bleed, make you cry, spend all your money, spend all your time, not work and not care that you will love more, the more they abuse you.” -Anonymous
the hardest part is getting it out of the car.
A replacement pump is, or used to be, $30, so if your time investment is worth it to save $20 and learn something extra in the process, have at it!
(and yes, you need to rent the pulley-puller-and-installer kit to get to the mounting bolts)2012 Mazda5 Touring | Finally working on the LTD again!
is it the pump seals or is it the lines? The return line is very commonly petrified to the point where it won't seal and it just vomits fluid. Even if its not, I'd strongly suggest replacing both lines when you do the pump rebuild. They're usually hard as a rock by now, and probably won't re-seal. Do not try to pull the return line off, you'll break the reservoir. Cut it off and replace the hose. Its just bulk trans cooler line with a clamp at each end.86 Lincoln Town Car (Galactica).
