I'm wondering if its a 90s thing. The 90-91 boxes had the same type of parking brake pedal as the round cars. Cables may be different than older boxes but the same as what the round cars want. I've been meaning to see if the front cable on a box can be swapped to something else so the cables all just fit without having to make anything. Probably will get to that next time mine breaks, which I have scheduled for the Teusday after the end of eternity.
MegaMerc destructed rear...
I stuck my nose under the car to squirt some penterating oil on it. The bolts are torx heads! What were they thinking?
All of them or just the two right above the differential like most I've seen?~David~
The Torx thing was not one of their more brilliant moments. No argument there.86 Lincoln Town Car (Galactica).
Originally posted by 87gtVIC View PostAll of them or just the two right above the differential like most I've seen?
Yeah, just the uppers.
Recieved gear install/bearing kit. Ordering a maincap support cover soon. Still don't have a new rear though.
Has anyone been to Crazy Ray's yards in MD? Any good?
Probably going to Harry's and/or EZ Pull next Fri.
EZ will haul it to the gate won't they?
Thanks
Originally posted by mitymerc View PostHas anyone been to Crazy Ray's yards in MD? Any good?
Thanks
EZ Pull has a couple boxes at least. They will usually drag a diff up the hill for you if you either flag down one of the guys in the truck or go up to the window and ask. If you don't need the control arms and don't mind paying a couple bucks, you can get the torch dude to cut the arms for you to get the rear quickly instead of having to fight with the bolts under the car.86 Lincoln Town Car (Galactica).
greble u pull it is closer to you.....myerstown
Originally posted by Lincolnmania View Postgreble u pull it is closer to you.....myerstown
I didn't know about this place.
I'll call them tomorrow.
