View Post
Running R-134 question
The only time the vacuum can possibly affect fan speed is in auto mode. What normally happens is the air moves to defrost. The fan doesn't slow down but it stops blowing in your face. It also shifts to hot when this happens.
The non-ATC cars have one half the size as the ATC cars. If the system isn't stupidly leaky it will work fine with any reservoir that works. if it is leaky, fix it. They are never going to be completely tight but if you pump the thing up to 18 inches or so and its still above 10 after a few minutes I don't think you'll have problems.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostThe only time the vacuum can possibly affect fan speed is in auto mode. What normally happens is the air moves to defrost. The fan doesn't slow down but it stops blowing in your face. It also shifts to hot when this happens.
Originally posted by Toploader View Post
Thain, not on my '86 MGM with ATC. Every time I would feed gas the blower motor would either slow down or go off completely. Long story short, the bottom of the coffee can was rotted around the seams, and the vac tree on the dash was leaking. After I replaced both no longer a problem.What I Own: 1993 Mercury Grand Marquis GS
Originally posted by Toploader View PostWait a min, I only purchased the small vac piece that attaches to the tree
