Trailer Module or Trailer Relays?
    Doing a little work on the '87 right now to get it properly setup to haul a trailer, and one of those steps is to ensure trailer lighting is working correctly. I'm a fan of taking the lighting load off of the vehicle circuitry and passing it to a "standalone" system.
    Now my car was not originally a outfitted trailer wiring car, so it lacks the four relays that were present on such models. Effectively there were four electromechanical relays present to run the left/right turn signals, running lights, and a battery charging circuit. The latter I'm unconcerned with as I dunno how comfortable I am with a 30 or 40 amp lead just running through the car like that to a 7 pin trailer socket. Regardless, I'm not sure what style relay was used at the time, but a standard Bosch cube style relay would work in this application if I opted to set things up similar to factory.
    The other option is to use a modern trailer light module of solid state nature that takes the load off of the vehicle circuit. Just like the electromechanical setup, it takes the load from the vehicle circuitry.
    Both of these setups use a dedicated power lead to power the system, so the input from the vehicle circuitry is just a signal to drive the output.
    Given the choice of the OE style electromechanical setup or the aftermarket solid state setup, which would you opt to use in this scenario?
    original relays were the usual Ford type of the era, a Bosch would be the sensible equivalent.
    Unless you have trailer brakes with an on-board battery the charging circuit isn't going to do you any good anyway.
    Only reason I might go for relays is they tend to be very serviceable. Not much to fail, and if one does fail its 8 bucks or something for a replacement. No idea whats in that module but I suspect its a "buy a new one" situation if something happens.
      +1 relays. That's what I used. It's not much more wiring either.
        I used a trailer light power module. I have never used it so I cannot comment on its performance other then my initial testing of the 4 flat plug ensuring everything functions as it should. I prefer the idea of the individual relays though because of Thains' reasoning.
          Well good deal then. Looks like I'll see to doing the relay setup install in the next few days. Thanks y'all.
