Okay, can't find anything searching the archives but that doesn't mean it hasn't been addressed before.
Vehicle: 1990 Colony Park LS
Symptom: Intermittent sudden loss of electrical power
Driving along after for about 15 minutes, I slow to a stop to wait for an "Wide load" to cross the local bridge. Radios going, fan blowing, engine purring. Suddenly it is like someone puled the plug. No engine, no radio. no fan, no power to anything. A few people help me push it off to the side and during the push the radio comes on for a couple seconds then off.
I poke around and find the negative cable is loose, wiggle it back down as I don't have any tools with me, nada. Look at the fuses, all seem okay, jiggle a few odd connectors still nothing. As I contemplate calling AAA, I decide to twist the key and it fires up. Total down time about 10 minutes
Start heading back home to switch rigs and it dies again. Same way, sudden overall loss of electrical power. Wiggle the same things, not luck. Wiggle the positive battery cable and find it is a bit loose. Jam, wiggle it onto the post a bit better. Starts up. Total downtime about 5 minutes.
I started the rig the next day with no problem. Since the only common item other than downtime was wiggling the battery terminals, I crossed my fingers and pulled each battery lead loose for a moment. Engine kept running.
Any ideas? To make it very clear: the main symptom is no electrical of any kind, though some items, dome lights, radio did come on before the starter/ignition would respond.
