87 crown vic......the trunk light doesent always go out.......anyone know where the switch is located?
trunk light problems
Tags: None
I think that might be the inertia switch you're thinking about (black box with a white button). The light is one of those mercury switches so I'm pretty sure it's either on the lamp or in the wiring just before.sigpic
1986 Grand Marquis LS 2 Door
mercury switch in light fixture... same as light under the hood for the light... have to adjust on level ground. my hood light turns on when on a hill because it angles back far enough to trick the switch. the fixture can be bent a lil to turn it off. if you want, remove trunk latch hook between tail lights so trunk dont latch. get in trunk and pull lid down so you dont get locked in and adjust the light.
Originally posted by lincolnmania View Post87 crown vic......the trunk light doesent always go out.......anyone know where the switch is located?
Originally posted by Grandpaslincoln View PostActually it IS a switch. It's called a mercury switch.sigpic
