I am in the process of figuring out a fuse box configuration that fits my needs.
Pete (85crownHPP) has done the swap himself and used maxi fuses for the Electronic Engine Control power wires originally coming from the starter solenoid.
My 86 EVTM tells me that the two powers for the EEC are protected by an 18 gauge fusible link and a 20 gauge fusible link. According to the fusible link rule this means that the actual wire gauge heading to the EEC are 16 gauge and 14 gauge respectively. This also means that the two are only really capable of handling 22 amps and 32 amps, again respectively.
Taking all of the above into account I don't really see a need to have these wires protected by a maxi fuse and would much rather use a "normal" sized fuse to do so. Am I wrong in believing this? If so, why?
