door chime after gauge removal!! - 89 GMQ
    ok i pulled the gauge cluster out and threw some LEDS in (looks great btw!)
    now when i put the key in, even after starting the car the door chime stays on as im driving, and the low fuel light stays on
    *edit
    ok the fuel light works normal now, idk what that was
    and the door chime issue is that i mush have messed the button up on the drivers side door when i stuck a boot in there to depress the button so it would STZFU while i was working. when i close the door now it no longer depresses the button enought to turn it off but if i press it down with my finger its cool
    1989 Grand Marquis GS
    pull it out and twist the switch housing part so it moves back out of the mounting flange portion some. You probably pushed it in too far with the boot lol
      led's dont work well for the idiot lights and the low fuel light.....they dont draw enough current
        good to know.
        *makes a note*
          This is especially true for the battery light, since there's always a small current going through the battery light. What will happen is that the battery light will be on all the time.
            airbag too
              i think i might have accidently put a LED in the feul light socket thinking it was a light light lol
                Originally posted by 1990LTD View Post
                airbag too
                yeah, and annoyingly the airbag system beeps at you if it thinks the bulb is bad.
                  I heard about that! I never tried putting current through it with the bulb out because it would be just my luck that it would beep and never stop. I replace that 194 every time I have the cluster apart for whatever reason just because. Where does the beeping come from, a chime hidden somewhere or..?
                    There's a beeper buried somewhere in the bowels of the dash.
