Hi!
My sister called me the other day: her brake light is on, on her 1989 colony park.
Of course, she checked, the parking brake is not applied.
I know that this occurs in two scenarios:
1) parking brake switch
2) pressure differential detected between the two sides of the reservoir on the master cylinder
So!
I'm thinking, since she says the car stops fine as it always did, it's most likely the parking brake switch gone bad, possibly, the rear brake lines (since the fronts do most of the braking anyway, it wouldn't be as noticeable-- leaky front brakes you wouldn't miss!).
Now, if it's the parking brake, then if you put the car into the "on" position (key in position II), does the brake light come on with the parking brake at that point if you apply it?
So if the light is on when you're in park, foot off the brake, then it can only be the parking brake switch?
If you just disconnect the switch, I assume the light will go off (unless of course, it really is a problem at the master cylinder)?
Just checking!
thanks!
-Bernard
So!
Just checking!
thanks!
-Bernard
