Vacuum leaks what lines are important
    I have an 1988 mercury grand marquis 5.0l and I was wanting to see which vacuum lines were important not worried about the climate control or the smog pump just what will make it run right
    Gotta have the big fat one going to the brake booster, the ones going to the PCV valve, and MAP sensor. Also the thin red plastic one going to the fuel PSI regulator on the fuel rail is a keeper. All the lines in the big bundle of plastic lines going to the passenger fender can be eliminated for testing. Just be sure to cap off the source.
    The ones that most often go bad, leak, and cause trouble are the MAP sensor line and the EVAP line (comes out from under the RF corner of the upper intake). Unfortunately to properly replace these you have to remove the upper intake, if the original spring clamps are still on them.
      All of them. There are only about a dozen. A leak is a leak, no matter what system it is in. Just replace them all and be done with it.
