Sorry Miamibob: I had to skidoo early to make a meeting and no internet at home.
The car is a 1986 Crown Vic 4-door 5.0L EFI
The Problem: Window goes down but will only go half way up and then binds. I noticed 2 small aluminum pieces that look like they were mushed in and sheered off of whatever they were holding. I noticed that the bracket that holds the window motor moves with the window gear. I was under the assumption that the motor stays put and the gear moves. I don't know the anatomy of windows, but I'm not sure anything is supposed to move aside from the window gear, the motor that turns it, and the window itself. When I removed the motor to get a better look, the bracket will move out of alignment with the 3 holes in the door panel. When I reinstalled the motor, I had to hold the bracket in place with a screwdriver and then install the motor. I don't remember having to do that last time I switched motors (last summer; rear door). Here are pics of what I found.
Are these the plastic pieces you're referring to? I only found 2 at the bottom of the door.
