What is this vacuum controlled thingy? It's located on the passenger side wheel well. I think it’s for the air pump. It’s been a long time ago since I removed the air pump I’m not sure.
I’ve already plugged off the 3 lines coming out of it from underneath, which makes me think I did it back when I removed the air pump. I would like to remove the whole thing if possible without causing any issues.
Can I remove it and plug off the lines?
