Anyone know how to get this annoying piece of s&@t back in the dash correctly?
Mark VI ash tray issues
I think a couple leaf spring clips are missing on that. Not familiar with a working Mark ash tray, but there is usually significant friction from the springs pressing against the sliders, and they probably double as retainers to keep things from falling out. That C bracket with the janky holes in the side may be where these springs where originally affixed. Might even have an underbracket that is missing that screws to the bottom of the dash to hold things together. As you might now, the ashtray assembly in a box is held in place by three screws, which leads me to believe something may be missing.
You have a castrated ash tray. There should be 4 balls in that slider assembly where the holes are blown out. Thats what sits in the grooves inside the dashboard. Thats also why it doesn't sit right or stay where it belongs. I think you may need a donor ash tray, that bracket looks pretty f'd up and it may not be possible to just put new balls in it. There are tabs that are supposed to capture the balls and it looks like yours have been bent or broken off.
The release is the tongue thing center top. Push it down and it slides right out of the hole. Putting it back in is slightly fussy but basically hold the tin slider thing towards the back with your finger and get it started, then the whole thing will just push right into the bracket with no real fuss.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostYou have a castrated ash tray. There should be 4 balls in that slider assembly where the holes are blown out. Thats what sits in the grooves inside the dashboard. Thats also why it doesn't sit right or stay where it belongs. I think you may need a donor ash tray, that bracket looks pretty f'd up and it may not be possible to just put new balls in it. There are tabs that are supposed to capture the balls and it looks like yours have been bent or broken off.
Taking a closer look at the ash tray it doesn't really look like the tabs that hold the balls are bent. It looks like the balls just sit in there and you kind of have to hold them in place while sliding the tray back in. I'll upload a couple of pics later tonight I'm at work right now and don't have good enough signal to do so. I just replaced the lighter socket in the ash tray so I pretty much have the wiring issue sorted out.Last edited by mercurygm88; 09-26-2021, 02:35 PM.
Originally posted by gadget73 View Postthey hold themsevles in place if the tabs are not bent out.
[ATTACH=CONFIG]57066[/ATTACH]
might have to tap them back over a bit to retain the balls, but it doesn't look as messed up as I thought it did in the video.86 Lincoln Town Car (Galactica).
Crown Vic and grand marq use a different, less complicated setup.~David~
Originally posted by 87gtVIC View PostCrown Vic and grand marq use a different, less complicated setup.
likely, but if you take the thing to the hardware store, just get one size under the one that won't go into the hole in the bracket. Or use drill bits to size it.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View Postlikely, but if you take the thing to the hardware store, just get one size under the one that won't go into the hole in the bracket. Or use drill bits to size it.
A 94 will probably have much different ash tray mounting hardware.
+1, '94 will be more like your '02 LSE.Vic
