1984 Grand Marquis GS - CFI-SEFI conversion, Explorer 302, GT40 intakes, GT40P heads, 1.7 roller rockers, HO Cam, ASP Underdrive Pulley, 2.5" Dual exhaust, Flowmaster Delta 50 mufflers, 3.55 Trac-Lock, Rear disk's, Moog cargo coils, ES rear poly bushings, PI front and rear sway bars, 3G alt., Mark VIII fan, custom Auto-meter dash 1990 Crown Victoria Country Squire - Explorer 302, HO cam, dual exhaust, 3.55 Trac-Lock, PI rear sway bar (SOLD)
Ok. I think i made a little Progress this afternoon. i took my test light And Took apart my drivers door panel. and tested the switches ( The wires gong into the switches actualy. all of them where getting fire . exsept for the passenger's up front. and it's a red and black line wire and a yellow and black liner wire. Any one have any clue of the route of theese wires? That way ill find where it might be striped and prob solved :-> I hope .... )
Hopefully this is good for a novice. Any\ how thanks guys/gals
Dark :->
I got an Idea Feller's ( I know thats scary ) Umm, Is it possibe to " Tap " into another wire that is hot during key on, and run it to the switch? i know the driver woldent be able to umm rollit down but at least my LF could
And if there is a way, May i ask how i might do this
Thanks Guys
Dark
i dont have a scanner, I just keep trying to take pics of them untill I get a good shot, lol.
The EVTM doesnt show you were wires are routed in the car so much as just a diagram of the circuit.
Ill take a gander and see if I see anything that may help. If you know of a diagram in particular you need Ill try to get a clear shot. Just dont say 'all of them' lol.
Hell, I guess I could xerox the whole thing and mail it to ya, lol
Just knowing where the wire's from the drivers door to the passenger door goes would be cool. :-> I can take my stuff all off and put it back together. but... I still might not hit it on the money :-/ eh. Thanks guys
Dark :->
::: Edit ::: Ok got a little bit of new info as well. Yesterday after i got my new plugs and plug wires i was gonna turn her over and i had to do my +Battery wire thing where i take it off scarpe the inside put her back on and when i ge it in just the right spot she will turn over. Well any how on one of my trys of turning her over i saw that the. Negative battery termanel had a poof of smoke come out of it for a second. What could Case this? or is this even any helpfull info? any how thought id just post it :::: End Edit ::::
oh, and i read my EVTM section on power windows (no wire routing) but it does say this:
"the power window switch sends current through the window motor in one direction for up and the opposite direction for down. If the off position, both motor wires are grounded through spereate switches"
so if you were testing with a ground, none of them should have lit up...
it looks like all the switches in the master switch share one power source and deliver it to either wire coming off the switch.
negative battery terminal is prolly dirty/ bad connection - have you taken the cables off and cleaned them?
10-4 on that, I bought a new Postive battery cable for it two weaks ago i belive and it got fried the weak after, thats when i decided it was time to look for the short. But i clean them on a Semi reg. basis
O and i havent cranked my car now in about mmm, 4 days now and i still have a charge
Ok, im at a stand still now. I cant fig out where my wires go that where cut and used for the sterio. Or even see where the reg wires would be,( For the sterio that is. ) Dont get me wrong i dont mind not haveing a sterio at the moment. As long as i dont have a short. but im really at a stand still... Any advise at all guys?
Thanks in advance,
Dark :->
I think what you need is a good cool dry day and a couple of good buddys and a nice wiring diagram. what I did for my old jeep is read the wiring diagram and colored in the diagram in to match the color of the wires so it is easy to read and find what you have or what you are missing. hope that this helps!
I got a question, sort of an idea. The wires that where cut. Are comeing out of the noodel. Could it be the other end is wraped n there in the noodel? it's got tape or something wraped around it. So im scared to cut it.. Any how thanks guys :->
Dark
