Someone on here had an LTD-S header panel. Is that 3G in there yet mang?
no the 3G was confirmed dead at autozone. I will wait till my current alt dies then get a new 3G~David~
Today i cleaned up my fender supports. They were badly rusted. I used a wire brush (with handle, and on drill gun) as well as sand paper to remove every last spec of rust. Surprisingly they cleaned up fairly easily. After getting them down to the bare metal i wiped them down and sprayed three coats of primer, then three coats of black, the three coats of clear. They look amazing, i almost dont want to install them because they look that good. Pics of the final product tomorrow.Last edited by 87gtVIC; 04-18-2009, 07:54 PM.~David~
Painted Fender Supports and HO Upper Intake
Pics as promised with a little something extra
My fender supports.
My HO upper intake.
I do not want to install either because they both looks so good.~David~
dude! You want to put the upper & TB on... the 85 with HO upperstuff on it is peppier than any stock box Ive driven!!!
You just gotta get the rest of the underhood cleaned up so its not such a contrastThats why I didn't clean or paint anything Ive put on recently (upper was already blue) since the rest of my engine bay is grimy...
ok ok i will put it on. believe me i want my car to be faster..just sucks that all the goodies that will be going on it will looks 1ooX's better than whats on the cars already. It looks as if i will have to clean some stuff up under the hood.Istill have to get my egr spacer bored out. so i have time to clean up the dirty things.
The only damn reason i painted the upper intake was because i painted the fender supports.~David~
High Output Upper Intake Installation and 90 TC Fan Shroud
Today my dad and i swapped out the upper intake, egr spacer and throttle body for high output goodness. the job went without a hitch till we started the car up and pressed the brakes and my p. side front brake line (where rubber hose meets metal hose) blew up. It looked like a shot of NOS was spraying under my fender. Very lucky it happened right at home not while i went out to test the new upper power lol. in fact i have been very lucky with brakes failing. After a 4 hour drive in my dads mustang we got it home int the garage and once we went into the garage the brake line blew. Once with my car getting it onto the inspection machine the line blew and now today just sitting in the drive way, just a mere 2 hours after i got home from school the line blew.
Everything removed.
Guess i didnt have a brass one lol
The new and old
Another...where did it go pic
The ho upper, egr and tb
A lopo and ho tb
all installed
I also installed my fancy 90 TC fan shroud. My old shroud was warped for some reason and was hitting the fan on occasions.
Here is a shot of the brake hose fail.
And here is a shot of the car being embarrassed because it burst its brake lines.
To top everything off while heating up the proportioning valve (with a torch) my dad and i managed to melt the dummy brake light sensor thingy into the valve itself. oops. it turned out to be a 120 dollar mistake. We ordered it from Ford, local parts stores didnt even carry it. We also made new brake lines from the p. valve to the d,side and p.side calipers. (The brake line from p. valve to rear dif. and diff to drums was done over the summer). Now i have all fresh brake lines and can brake like a champ in confidence..well at least tomorrow when the p. valve will arrive.
and one more of the damn p. valve.
i didnt get to drive it at all because after the job was done my dad stepped on the brakes and a brake line blew, i am waiting on parts.~David~
Got the proportioning valve today, and installed it. My car stops again lol. I also got to drive it! Just have to figure out why my idle is higher than normal.
The new proportioning valve.
Proportioning valve installed.
And the fucking retarded place where the computer is retained. I just spotted it, i did not put a new computer in. At least it looks like where the computer sits. lol
Nice! glad to see it all on the car! Hows it feel? Any noticable power increase? Whats the car idling at?-Phil
Originally posted by Brown_Muscle View PostNice! glad to see it all on the car! Hows it feel? Any noticable power increase? Whats the car idling at?~David~
While i was at Citi Field for some activities my dad fixed the idle. The hole in the butterfly of the HO tb was too large, causing my idle to be higher that usual. He did something to it to make the hole smaller so now my idle is back to where it should be.:woot:~David~
it is a lot peppier than stock thats for sure. there was so much crud on the old intake and tb that it was definitely wasting some power. It feels pretty good with the ho upper stuff installed especially a good tb bushing~David~
awesome mang! good to hear! now, what kind of rear gears does it have in it?
Ohh and are you going to Scottfest this year??Last edited by Brown_Muscle; 05-04-2009, 01:37 PM.-Phil
