Cool, I wish my plenum was that easy to port... I'm not sure how I would get all the way in the plenum without some special tool. Did you notice a gain in power?
Can you 5.0L guys just purchase a ported aftermarket intake?
Yep we can, however. Our intake plenum is much larger than the 4.6L's 6" tube. So the cost is a lot more. Last I checked a ported HO could be obtained for around $600-$700 for upper and lower intake.
This particular one will go for less than it should. And if I didn't have to buy a tranny, I'd prolly get it myself! The reason is that thiis version only works on 94-95 mustangs. And because of the bend you can't turn it around to work like stock CV, TC, GMs. However, I just happen to be ussing the 94-95 engine. The piture is of the engine that I have in my Vic.
