My '90 LTD Crown Vic
    Originally posted by johnunit View Post
    Nice cat, where are you installing it?
    Well away from any gaskets!
      he's the mechanic kitty. he reports no danger to teh manifold.
        that duz it, you must uploads to icanhascheezburger.com.
          Ive always heard of catalytic converters being called cats, but this is RIDICULOUS!
            two crappy pics of the new stance
              buy some better valve cover gaskets......the cork ones do not hold up well.....i would get felpro permadry gaskets
                Eek. Are the rear wheels on uneven ground? Looks like a dog trying to scratch an itch. And reminds me of why my P72 looks lousy with wagon springs in the rear.
                  my driveway/yard aren't even so no it's probably not on even ground
                    lol
                    My car looked pretty funny parked partly in the ditch at the end of my mom's driveway.
                      this
                      I had oil leaking onto the exhuast manifolds within 2 years of using the cork ones.
                        thanks...right now cork gaskets will be better than leaky original gaskets. it'll get new rubber ones the next time i have the motor apart.
                          Ditto that... rubber is better than cork, but perma-dry is best (but expensive)... i think they were like 30 bucks when I got them for the 85... but the box was open, they had greasy fingerprints on them, so they gave them to me for half price!
                            There's a 4000lb paperweight sitting in my driveway!!
                            Not a fucking chance I'm even going to turn the car over without the TV cable hooked up, so it's going to sit until I get the pieces I need.
                              Got the tv cable from the junkyard today. The cat that helped me take it off the car only charged me 10 bucks because I gave them the parts car in the first place
                              yanked out more smog/egr stuff today, but thought I made a mistake because the car would NOT idle properly afterwards. swapped out the new TPS I installed, still won't idle. Swapped out the IAC I installed....bingo. bad iac right out of the box. Emailed RockAuto about it.
                              It's amazing how much superfluous emissions garbage was on this car. I got rid of 3 solenoids (TAD, TAB, EVR), a pile of colored 1/4" vac hose and associated connectors (Ts and splices), and the vacuum hockey puck from up on the firewall.
                              I think the only things pulling vacuum now are cruise, brake booster, and fuel pressure regulator.
                                ...and the MAP sensor, and the EVAP system
