The tale of the 87' Colony Park
    Fapfapfap
      Nice. Thats a Cobra blower, right?
        It's actually one of those kinda rare first gen Lightning kits. A 2.2L Blowzilla. Ironically the snout bracket was cut down for a 302, then welded back up for a 351, and now I have to cut it back down for a 302. I just finished blasting it actually.
          Oh Jesus. I better step it up than.
          I cannot wait to see/hear this. Actually, I could probably hear this from my house.
          08 Lincoln Navigator L - 233k
          03 Mercury Marauder- 63k
            Did I hear talk of ze blower? Cant wait for this!!!
              before hacking it, why not get a 351W roller block. It's not gonna split the 351W block.
                I've thought about it...
                But I rarely see any F4TE blocks in the yards, and with my luck one I find will have cracked cam bearing journals. Then I need to find a Lightning lower, special headers, ect....
                  I see a lot of the lowers. Headers are off the shelf.
                    We'll see....
                    Picture time!
                    Chemdipped and sandblasted the blower plenum/intake and painted it to match. Came out good I think.
                    The money [s]maker[/s] taker.
                    Just cleaned it up quick, initail inspection looks like it's in good shape.
                    Looks like it's had a little cleaning up done.
                    Nice and clean inside:
                    Quick mock up...
                    Compared to a regular gt40 upper (yes I know it's not going to fully fit under the hood)
                      Was just going to ask about hood clearance when i got to the last pic lol............should be alot of fun!
                      Rodney Tolleson, me at the track.....future drag box racer!
                        1" cowl hood... done.
                        better yet... mod the hood at the factory lines to raise the entire center section to the needed height.
                          Love the valve covers. There was a guy years ago that had the factory towncar hood raised on the bodyline. Should do that. If you do the minimum you need to clear the blower it'd look stock. Could also make your own motor mounts and drop the motor a little
                            Nice score on the blower. I don't have enough patience to find one of those when I was considering my options with my wagon.
                            You will most likely need to modify the throttle cable, and possibly run a lightning spacer / egr delete. Hopefully everything clears for you.
                            1989 Ford Mustang LX...............................1989 Crown Victoria Country Squire LX..
                              This is gonna be awesome when done.
                              Past Panthers
                                It MIGHT close.
                                Worst case Ontario, you'd have to trim the bracing.
